[SOLVED] Problem with MPLAB SIM
ljcox
Full Member level 5
Full Member level 5
Melbourne Australia
I have a Desk Top computer that employs Windows 7.
I have MPLAB V8.92 and have an unusual problem with a programme I am currently writing.
Using MPLAB SIM, I cannot see any change to PORTA in the Watch Window when I attempt to simulate an output change.
Below is a sample of the code. After executing bsf rly, there is no change to PORTA.
I set TRISA to make RA4:0 outputs.
I had this problem several years ago with another programme I was attempting to stimulate, but unfortunately, I can't recall what I did to fix it.
I have explored the options in MPLAB but cannot find anything that will fix the problem.
I even used Control Panel to repair MPLAB but that didn't make any difference.
Any assistance will be appreciated.
#define chk_sw PORTA, 0 ;applies +5V to switches
#define rly PORTA, 2 ;relay
#define buzzer PORTA, 3
ORG 0x00 ; processor reset vector
call init ;Initiate parameters
bsf rly ;operate relay
You didn't mentioned which controller of microchip you are using.
And i think its not a MPLAB SIM problem, most of the pins of PORTA are configured as Analog to Digital Converter pins by default.
So you have to change there state to Digital Input Output pin and then only TRISA = 0x00 will work on it.
Reactions: ljcox
    ljcox
Thanks for that suggestion, it fixed the issue.
I'm using a 16F628A. I had forgotten that it has analogue inputs as it is a long time since I last used one.
