Problem with MMC card initialization in Proteus
harish.n.j
Junior Member level 2
coimbatore
Hi all,
i am planning to work with data storing in mmc card, am using PIC controller. I have even Driver which is provided by CCS. but when i try to simulate with Proteus. while designing circuit , it asks for image file, i have no idea about it ? , i have come across a similar thread asking this imag file, but it dont seems to be providing a right solution for me
wat are the initial parameters must be done to use MMC card with Proteus?
thanks in advance !
Re: sd card doubt
Attached is image file.
Rename it with extension ".mmc" as edaboard does not allow to upload a file with this extension so i changed its extension.
Re: sd card doubt
probably it could not be attached,if u give me your email i can send u the file
Re: sd card doubt
Thanks waqas, I have sent u my email address to ur personal message.
could anyone provide me some link to any sample application regarding using proteus sd card
Re: sd card doubt
Card image file sent to your email.
I would suggest u to use mikroC compiler.It has example code for interfacing with SD card and schematic too.
    harish.n.j
Re: sd card doubt
am searching for a link to download MikroC found a link but its 14 MB size but it does not contain any examples, it would be great if u provide the link where i can download the examples... thanks waqas for ur quick reply !
Re: sd card doubt
hey waqas thanks a lot man !
but does this file contains library files also
Re: sd card doubt
hey waqas, thanks man this mikro C seems to be gr8, and the other prgms along with it seems to be rocking.. am going to work on it this weeknd . :D
Re: sd card doubt
Disable antivirus.
have you provided a resistive voltage divider between controller and SD card???
most MCUs work on 5 v while sd card work on 3.3 v so you need a voltage divider.
Re: sd card doubt
ya i have added resistence to drop the voltage.. i have uploaded the proteus model below
Re: sd card doubt
you will be surprised to see my answer :p
dont use resistive network in proteus but always use it in actual hardware.
Attach MCU and sd card directly in proteus
Re: sd card doubt
i removed the resistence . but still the same response is there any mistake in SPI initialisation
Re: sd card doubt
I think u r checking if initialized properly by displaying "u" on usart terminal.Have u set usart terminal to 19200 in proteus too?? if not right click on it and set it
I recommend to use slowest baud rate for testing like 600(in both, coding and in proteus)
Added after 9 minutes:
Another important point ,u should use same clock rate in mikroC and in proteus.In proteus right click the processor and set its clock speed,proteus do not simulate external crystal attached to processor.
Re: sd card doubt
ya i get the reply from the terminal. as "UWi". what may be wrong
Re: sd card doubt
no, actually my problem is with SD card initialization. i never had pblm with serial communication.
as per the program if the reply is "Ui" or "i" then the it means SD card is initialized but the reply i get is "UWi", which means Init() function does not return 0, which means initialization is not done correctly
what might be causing this problem
Re: sd card doubt
this is because you are only checking if card is initialized,if not you go forward.
try this
while(mmc_fat_init(&PORTC,2)) ;
The program counter will stay here untill initialized
Re: sd card doubt
Hey waqas thanks for your gr8 support, actually i tried as u said with the while loop but it was repeatedly printing WWWWWWWWW continuously, anyhow i solved the problem by modifying the example project file as per my code. it worked !. thanks a lot man u had provided me a good start !
