Problem with Metronic Zapbox Single 4.2 (DTT)
rgb83
Junior Member level 1
Hello Edaboard community,
The problems began days ago when my DTT (digital terrestrial television) suddenly frozen the television image and remained in this state untill i switched off it.
Instead yesterday it doesn't turn on anymore when I press its button. To be precise its led is turned on for a while and immediately turned off.
I suppose it can be due to malfunctions in some capacitor/s but to be honest I don't know how to check it.
Which are in this case the correct steps to be followed in order to find the problem source?
I will try to follow your suggestions as much as possible.
Unfortunately i didn't find any online service manual, but i have the code which is written in the PCB board (E254667).
Thanks in advance.
May I ask you to have a look to the above message. Thanks
I know it is a good habit to be patient and wait an answer but why none is trying to put an answer? Is it the wrong forum section?
