hobbss
Member level 2
I have a board that is about 50% routed (manually). Suddenly, I can no longer route "normally." If I am in "Add Connect" mode, and click on a pin, the net does not snap to the connection point. The only way to get a net to start on a pin is to first select the pin (while in idle mode), and then begin the "add connect" command. Then, when I get to the other end of the signal (i.e., another pin), the only way to get the etch to terminate properly on the other pin is to right click, select "snap to," and then select pin. It seems like this must be some kind of grid issue, but I can't figure it out. I can't even go back to previously routed components and add new etches. It is almost as if the router is on a different grid setting then everything else, but the grid options are still the same (25 x / 25 y) for all etch. Has anyone seen this, and if so, how did they get around it? If there is a third option (after starting over and doing the multiple click routine described above) for the >200 traces left on the board, I would rather do it...
