Hi hg81,
Is it OK for your design if Clk2 & 3 an extra 2.3nsec delay have to Clk1?
I mean do you wish it so? Others I would connect both ICs pin3 to Clk-In...
Check pls on both Vd pins(1/2&6) per Ohmmeter & on the IC pin direct that it has connection (zero Ohm) to VD`s 3.3V, than same for GND connections on bot ICs Pin 4&/!
Apropos; how high is your input clk pls?It must be minimum +2V peak & as zero down to maximum +1.3V if not at zero is...
Others said a pulse between 0...+2...+3V!
Its not clear me; you dont have some clks on all 4 outputs, or clk1 is in function?
K.
