Problem with LPT port under WinXP
aamiralikhoja
Member level 5
Member level 5
Hi to all
I porting my windows 98 programm to windows xp sp2 .
My programm using Ecp parallel port to access Ecp Fifo . I am using device driver
for acessing port registers . Programm works well on windows 98 but it runs
some time on windows xp then stops working What is the problem same PC is
used for programm .
Re: help me if u can
It is known feature of Windows XP. The solution of the same problem is given here:
https://www.coolcircuit.com/project/picprog/
By the way, next time give descriptive name for the topic.
It was : "help me if u can" . I change it to "Problem with LPT port under WinXP".
Hi
You can find good information on
Salam
Hossam Alzomor
www.i-g.org
use userport. Install it then everything will work
IT is due to the security to the parallel port
Bibin John
www.bibinjohn.tk
access parrallel port in XP is restricted you have to use some types of drivers to use it.
Added after 1 minutes:
you can also use socket programming in .net framework
you can also try installing the totalio.sys driver from www.talkingelectronics.com
the driver is originally intended to enable the PIC programming software, IC-Prog to work in WinXP/2K. the program uses the serial port to program the PIC MCU. i think this should also enable other programs that directly access the serial and parallel ports to work. i'm not sure though...
