Blackdragonier
Junior Member level 1
Hi.
I am new to this forum. If I make any mistake regarding the post, let me know.
So, let me start with the whole story. I am using a logitech normal 2.1 stereo audio setup for my PC. Last 1 month I noticed that my right side speaker has less sound than the left side. So, I searched for online tutorials and found not so close but helpful tips. Both speaker goes through one single 3.5mm jack to the back panel of the speaker. I checked the speakers with my laptop and android cellphone, but both speaker sound output is at same level. This is how I came to know that I should check the inside of the PCB of the speaker system.
So, when I checked the PCB there was one capacitor got swollen and from the Youtube tutorials, I learnt that I should remove and replace it with the same type of capacitor. Before removing the capacitor, I used a tester screwdriver to check the responses of on different capacitors. And my left side speaker buzz sounded very high. And the right side had lower buzz sound. Also, it has a 3rd speaker under the bass control system. After doing the tester screwdriver buzz sound test for 2 - 3 minutes, then the sound stopped permanently. I got scared if I might damaged any parts of the PCB or speaker. Then I immediately removed the faulty blue color swollen capacitor and replaced it with the same type of new gray color one (check attachments). After that, I checked if the tester screwdriver buzz sound would work again. But nothing happens now. Edit: the speakers still works fine with Laptop and cellphone but not with the amplifier. Also, even after replacing the capacitor, no sound output is coming of any of the speakers. I checked for the power availability with my multi-meter and it seems fine. I also tried checking the components using tutorials from Youtube but I think I am beating about the bush.
I am actually confused if something happened to the PCB or components that I am unable to check through. Please help me out here. How should I do the checking properly? Any step by step guidelines for checking the PCB or sound system would be helpful. I have attached a short video and some pictures of the audio system.
Thanks in advanced. If I am missing anything also let me know. I am not an engineer, just an enthusiast who is trying to DIY, as there are no known such engineer in my area.
Regards Imran
Regards Imran
