Problem with Linux kernel panic (no init found)
reckless
Member level 1
Member level 1
hi there
if anybody can help me i ve been facing this prob and didn't find the answer , i ve compiled the kernel do these steps
my root is (hd0,4)
idid
make mrproper
make distclean
make xconfig
make dep
make clean
make modules
make modules_install
copy the image to the /boot
i am using grub so i did
mkinitrd arch/i386/boot/bzImage /boot/vmlinuz-2.6.13.1
copy vmlinux to /boot/vmlinux-2.6.13.1
edit grub.config in there ive a confusion at root=/LABEL /hdb scsi...
i put it same but when i was creating the bzImage it displayed root(3,7) what's that ?? should i have to change something in grub
i make changes to initrd that is made into the grub but
when i boot my PC it gives kernel panic no init found
can anybody help me out
linux kernel panic
If ur compiling kernel for first time it is always recommend to us lilo inside of GRUB
lilo is straight forward
Re: linux kernel panic
Hello,
It nearly sure you have forgoten to defne initrd=/initrd.img. It is necesary to boot a 2.6 kernel.
Good luck
TaPa
thanx i did it the problem was with the file system ext3 support in x config
thanx:D
