problem with LCD; mikroc-pic
Did you compile the code using mikroC? Send your hex file.
The problem is caused by this code
if(ss_select&&copy_set!=0)
  intcon=0xA0;
  if(io)
   intcon=0x00;
   rly1=1;
   one=0;
   rly2=1;
   ten=0;
   led=1;
i attached the hex file. for testing purpose i changed the Min to sec in smh value.....check this?
but the code is run only io is in 1 condition.initially io is in 0... then how it will cause the output
  • 0-99min hex final.ZIP
Check with this hex file.
  • timer.rar
Reactions: mailus
    mailus
interesting my problem solved,,,,,great
but the user input"00"shows as"/0".
point my problem please.
Check in proteus. Is it displaying 00?
add these lines after OPTION_REG = 0x07;
ss_select = 0;
copy_set = 0;
Reactions: mailus
    mailus
yes, proteus shows "00". but in real time it shows "/0"
why it is followed by option_reg=0x07; what's the reason.
i corrected the code.my problem solved,,,, i found reason for my problem....thank you very much internetuser2k12. whenever i need help i will contact you....
what was the problem?
The display /0 problem solved. assign the one and ten value to zero after copy-set value assigned.
