Problem with launching IC50 on Linux
markli
Junior Member level 1
Taiwan
how to ic50
after I installation Candence IC50 on linux
I use icfb command to launch IC50 ,I always get message "NO such file or directory"
and I set ENV as below:
####ENV for IC50 #####
CDS_LIC_FILE=/EDA/license/IC50.dat
CDS_INST_DIR=/EDA/cadence/IC50
CDS_Netlisting_Mode=Analog
CDSDIR=$CDS_INST_DIR/tools.lnx86 <--------I use this instead "tools"
XKEYSYMDB=$CDS_INST_DIR/share/cdssetup/tdmX11/XKeysymDB
XNLSPATH=$CDS_INST_DIR/share/cdssetup/tdmX11/nls
PATH=$PATH:$CDSDIR/bin:$CDSDIR/dfII/bin:$CDSDIR/SKILL05.00/context
PATH=$PATH:$CDSDIR/SKILL04.60/context:$CDSDIR/infotools/bin
PATH=$PATH:$CDSDIR/dracula/bin
who can help me ?
Thanks in advance!!
cdsdir unix
you need to `export` all the variables , and `source` the file
and do echo $PATH to see that the variables are set
also soft link tools to tools.lnx86
license_ic50.dat
i had had "source" this file already
i use "setenv" command to check environment
it's OK
but it still doesn't work
if i use "tools" instead "tools.lnx86"(both env file and tools.lnx86 directory)
it can launch
but in CIW window also have the same message
it can open composer
but it always get this kind of message
"also soft link tools to tools.lnx86"
do this?
Your license
You can check ypur license file's property whether the user has the read right, and the license file has the unix format.
Good luck!
