Problem with Keils debugging in edge trigger mode
volkan
Newbie level 6
Newbie level 6
tx interrupt problem in keil
Hi all
i am writing a protocol for 89s52 and using assemly in Keil. I want to use 89s52's external interrupts in edge trigger mode(by setting IT0 and IT1 ). But Keil ignores my edge triger setting, It still work as in level activated mode.
For example when i begin debugging,i clr external interrupt inputs before running, and after running the program it directly calls external interrupt routine . Do you have any idea about this?
Re: keil's debugging problem
Thats very strange. Maybe you dont cofigure all parameters well.
Which ke|L you use?
Did you try to program real mcu and try same thing to see what is happend (for instance turn on some LED in interrupt routine for external interrupt occurence).
Regards.
Mr.Cube
ke*il's debugging problem
Check ur target options to see if nething is different. It works in both modes I've tried it.
thank you all,
i couldnt understand why it happened but at last i did the project by another way,so it works now..
tx
keep away form external interrups at 89s52.
I had the same unresolved problem and I had to find another way to trigger an interrupt.
It would have been wonderful, the datasheet assures a clean interrupt, but it was't so.
Maybe that generation of chips had some bugs.
Hi
I used to find that bug too while debugging interrupts. It's no real problem since the settings are correct and your main concern when debugging is to get in the interrupt, not the way you get there. I observed that the newer versions fixed that bug.
Best regards
