Problem with Keil C program
onde
Junior Member level 1
keil c-Problem
hello!
I have a problem with the following program:
// Timerinterrupt
#include <reg517a.h>
void INTTIM0 (void) interrupt 1
{ if (P4 < 0x7f) P4 <<= 1;
if (P4 > 0x02) P4 >>= 1;
TH0=-39; // 10ms
TL0=0;
main()
P4 = 0x01;
TMOD = 0x01; // Timer 0 Mode 1 16 Bit
TH0 = -39; // every 10ms Int.
TL0 = 0;
ET0 = 1; // Timer 0 Interrupt disabled
EAL = 1; // enable all
TR0 = 1; //
while(1)
The Problem is, P4 is shifted only 1 time (from 0x01 to 0x10), after this nothing is happing.
Any Idea ???
not so clearly
what you mean that P4 swaps only once, for it to shift from 0x01 to 0x10 it MUST be shift FOUR times???
forgoten issue
You place both statments as an if, instead of blocking the statments as [if]
[else]
blocks.
I mean that in the next shift, P4 shift one time to the LEFT: 0x02 -> 0x04,
then the next if statment take place: P4 shift back to RIGHT: 0x04 -> 0x02.
The sequence occur each interrupt cycle.
Change the statment to [If] [else] block!
thx for your answere and for you hint :)
aua, I think it´s not my day.
bye
an other thing:
even if my compiler accepts
while (1)
I write:
while (1)
also had bad experience with:
blablabla...
goto xyz_label;
blablabla...
xyz_label:
one of the compilers I'm using wanted to see the ";" between the label and the bracket
thomaz
C-problem
Hello onde,
Please describe your problem clear, so other people can help you.
Your problem isn't a compiler or even ke*l problem.
I guess you wish to realize a constant and repeatedly shift through P4.
If so, you have to register wether the two shift events reach there bounderies. If so, register and turn around the shift direction.
Please post for more details.
Robby
if you put th second condition in an ELSE statment, you will get the seceuence: 1, 2, 4, 8, 16, 32, 64, 128, 64, 128, 64, 128 ... and so on, because you have to decideif you are Up-shifting or Down-Shifting. Sometihg likethis wil go well,
unsigned char UP = 1;
void timer0 interrupt() using 1{
if (UP)
if ( (P4 <<= 1) < 0x80 ){
UP = 0;
else
if (UP)
if ( P4 < 0x80 )
P4 <<= 1;
else{
UP = 0;
P4 >>= 1;
else
if ( P4 > 0x01)
P4 >>= 1;
else{
UP = 1;
P4 <<= 1;
............... Rest of routine
the Optimized Code as follows:
#define true 1
#define false 0
typedef bit bool;
bool UP = 1;
if (UP && P4<0x80)
P4 <<= 1;
else if(UP)
UP = 0;
P4 >>= 1;
else if (P4 > 0x01)
P4 >>= 1;
else
UP = true;
P4 <<= 1;
Hello onde,
In my opinion, your problem may comes some usage restriction.
P4 is declared in reg517a.h as of below.
sfr P4 = 0xE8;
In my case, whenever I use the special funcion register(sfr),
I use the replace variable of unsigned char type.
unsigned char IO=0;
IO = P4;
if (IO < 0x7f) {
IO <<= 1;
P4 = IO;
if (IO > 0x02) {
IO >>= 1;
P4 = IO;
TH0=-39; // 10ms
TL0=0;
main()
P4 = 0x01;
TL0 = 0;
TR0 = 1; //
while(1)
