fateme m
Junior Member level 3
![Junior Member level 3](/styles/images/ranks/clevel3.gif)
i have a simple code i synthesized it no errors or warnings but after simulating it there is a problem ! the code is supposed to do this:
in the input there is a pulse wave if the period of the input pulse is more or equal to 1 ms the input goes to the output but if the period of the input pulse is less than 1 ms, a pulse withe a period of 1 ms goes to the output(frequency of the board is 50 MHz) the problem is the ON-time FOR the input instead of being 1 is X!!!! can't figure out what the problem is:bang::bang:
here is the code , the test bench code and the picture of simulation:
testbench:
![1.JPG 1.JPG](https://www.edaboard.com/data/attachments/54/54187-1d7334b6573893545985f32104186733.jpg)
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 ---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 19:39:42 06/13/2015 -- Design Name: -- Module Name: limit_s - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity limit_s is Port ( in1 : inout STD_LOGIC:='0'; out1 : out STD_LOGIC:='0'; clk : in STD_LOGIC); end limit_s; architecture Behavioral of limit_s is signal d: std_logic:='0'; signal flag: std_logic:='0'; signal cnt : integer range 0 to 50000; signal cnt1 : integer range 0 to 25000; begin process(clk) begin if (rising_edge(clk))then cnt1<=cnt1+1; if (cnt1=25000)then cnt1<=0; d<=not d; end if; if (in1='1')then cnt<=cnt+1; if(cnt>=25000)then flag<='1'; else flag<='0'; end if; end if; end if; end process; process(clk) begin if (rising_edge(clk))then if (flag='1')then out1<=in1; else out1<=d; end if; end if; end process; end Behavioral;
testbench:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 -------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 23:32:23 06/13/2015 -- Design Name: -- Module Name: D:/ISE_PROJECTS/speed_limit/speed_limit_tb.vhd -- Project Name: speed_limit -- Target Device: -- Tool versions: -- Description: -- -- VHDL Test Bench Created by ISE for module: limit_s -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- -- Notes: -- This testbench has been automatically generated using types std_logic and -- std_logic_vector for the ports of the unit under test. Xilinx recommends -- that these types always be used for the top-level I/O of a design in order -- to guarantee that the testbench will bind correctly to the post-implementation -- simulation model. -------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --USE ieee.numeric_std.ALL; ENTITY speed_limit_tb IS END speed_limit_tb; ARCHITECTURE behavior OF speed_limit_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT limit_s PORT( in1 : INOUT std_logic:='0'; out1 : OUT std_logic; clk : IN std_logic ); END COMPONENT; --Inputs signal clk : std_logic := '0'; --BiDirs signal in1 : std_logic; signal out1 : std_logic; BEGIN -- Instantiate the Unit Under Test (UUT) uut: limit_s PORT MAP ( in1 => in1, out1 => out1, clk => clk ); -- Clock process definitions clk_process :process begin clk <= '0'; wait for 10 ns; clk <= '1'; wait for 10 ns; end process; process begin in1 <= '0'; wait for 0.6 ms; in1 <= '1'; wait for 0.6 ms; end process; END;
