zenniz
Junior Member level 3
I'm trying to replicate a charging circuit for Iphone 3 and 4.
I'm supplying a 5V to the charger using a power supply with the current nob adjusted to the max. (3A)
I tried supplying 2V to both D- and D+ but the Iphone keep displaying " Charging is not supported with this accessory ".
The multimeter shows ~80mA when the Iphone is plugged in with " Charging is not supported with this accessory " message and almost 0A when unplugged.
I tried 75k ohms and 50 ohms but it doesn't help either.
I got the resistor as close as it's rated value. (100.1K, 100.2K and 150.1K 149.9K)
What is the problem???
