32bits
Newbie level 3
![Newbie level 3](/styles/images/ranks/alevel3.gif)
Hi, I am new to the forum, nice to meet you everyone!
I am working on a project that needs to do an interrupt from external source (RB0/INT) every time that there is a falling edge (TTL), at the moment I am just testing it with a push button, but the final idea is to use a quadrature signal as a input, similar to an encoder signal (I do not know if that can be done yet), but I want to go step by step. Below is my code, basically every time that I push the button it should go to the interrupt but it won't go when I am debugging, I do not know if I am doing something wrong, i would appreciate your help.
By the way I am using boostc compiler and pic16f877a. Many thanks.
My configuration:
#include <system.h>
#ifdef _PIC16F877A
#pragma DATA _CONFIG, _CP_OFF & _PWRTE_OFF & _WDT_OFF & _HS_OSC & _LVP_OFF
#endif
#pragma CLOCK_FREQ 16000000
void inter_set();
void main()
inter_set();
while(1);
porte.0 = 0;
void inter_set()
trisb = 0b11111111; //PortB as input
trise = 0b00000000; //PortE as output
option_reg = 0b10000000; // Interrupt on falling edge of RB0/INT pin
intcon = 0b00000000; // Clear interrupt
intcon = 0b10010000; // Enables the RB0/INT external interrupt
void interrupt()
porte.0 = 1;
clear_bit( intcon, RBIF ); // Clear flag bit
My configuration:
![rb0_int.png](https://www.pyroelectro.com/tutorials/embedded_priority_interrupts/img/rb0_int.png)
