Problem with installing IC5 on Linux
CRiSP
Full Member level 2
Full Member level 2
ic5 install problem
when i install ic5 for linux at redhat9,it says:
tar: This does not look like a tar archive
tar: Skipping to next header
tar: Archive contains obsolescent base-64 headers
tar: Error exit delayed from previous errors
/home/chensw/eda/cadence/cadmos/install/bin.lnx86/softload: line 1412:
Could not extract information from FS.0 of CD#1.
Could not get platform or release information: command not found
how do i solve ?
I think I've found some error warning messages like this when I tried to IC50 in Solaris with the recent version of "tar" program. Therefore, I went backward using the older version and it work!! Perhaps you may face the same situation.
old version!!!!!!!
old version?
red hat or tar old version?
help
Amuro said:
Only "tar" program.
can you give me an old tar package ?
I think "tar"'s version of Redhat 8 is OK. Then go to this site and get the rpm.
Force to install it to another path of your default tar program (use symbolic link to point the system to use the old tar for a while), so after complete IC5 installation, you can switch back to use your new one.
thanks!
thanks!
Re: thanks!
thanks!
but,when i install,it says:
Preparing... ########################################### [100%]
package tar-1.13.25-11 (which is newer than tar-1.13.25-8) is already installed
file /bin/tar from install of tar-1.13.25-8 conflicts with file from package tar-1.13.25-11
file /usr/share/info/tar.info.gz from install of tar-1.13.25-8 conflicts with file from package tar-1.13.25-11
file /usr/share/man/man1/tar.1.gz from install of tar-1.13.25-8 conflicts with file from package tar-1.13.25-11
how do i?
Re: thanks!
chsw said:
thanks!
how do i?
it seems that 7.2 tar is also
who can help me?
uninstall previous tar!
rpm -e
  1. you may also use gtar instead of tar.
rpm -e
  1. yes!
    now ,i have installed an old tar(8.0/7.2) version package at redhat9
    but ,when i install ic5,it still says above the error.
how do i?
I've 2 solutions in this case. Firstly, try to use --oldpackage with "rpm" command to downgrade your "tar" program to the older version. The other is build the older "tar" from its source (tar-1.13.25-8.src.rpm) and place it in somewhere e.g. /tmp and uses symbolic link for your temporary calling older "tar".
Oh, Sorry! It seem I'm too late to post the above comment.
So if your problem is still exist, I have no idea how to solve. It probably be there are some other libraries not match to IC50. I've heard some e.g. glibc. The other experts may can give you another advice. Furthermore downgrading your RH release may be a good choice.
