jortorri
Newbie level 3
Hello all. Thanks in advance to every person who try to help me. I hope to be able to help others in such things where I can.
I'm having a serious problem in my circuit. Is a very simple application that consist of a digital circuit (uC+xtal+digital inputs+1 analog input+1 digital output driving a transitor with an IR LED) powered with a linear regulator 7805. The consumption as you can guess is quite low (30mA @5V). The regulator is being powered by a 24VDC external SMPS. Everythings works perfect. OK. From now on:
- First test. Prototype A with voltage regulator TO220: I install an inductor 50uH at the input of the circuit. Now the regulator gives 11 volts!!, the input remains at 24VDC. Why?. With the scope I don't see nothing strange but the 11 volts.
- Second test. Prototype B with regulator SMD: I do the same test with another prototype identical to the first one except that the regulator is SMD. Now the regulator works well.
- Third test: Prototype C with regulator TO220 and other layout. The prototype C is the same circuit but the PCB is diferent. In this case the first minutes the regulator worked well but a few minutes after being powered, ups!!, the regulator starts giving 11V!!!. Ths scope continues without helping so much.
- Fourth test. Prototype C with regulator SMD. 11V!!!.
Any idea??? :sad:.
Here you have the basic squematic:
Any idea??? :sad:.
