Problem with implanting CCS in Proteus
cb30
Member level 2
Member level 2
no source line at pc address
Hi all.
I have tested CCS Compiler in Proteus with cod file in Proteus.
In older CCS version work OK , but on last version dont work.
CCS cod file is corrupt or have another distribuition?
I have tested with all option. "Standard .COD","Expanded .COD." but it dont works.
Thanks in advance.
Regards cb30.
ccs proteus
HI,
I am sending you the latest version of the loader fallow the instruction inside the loader and installed it or copy it ,
Then check it please confirm back if you get in work,
one thing more which version of the proteus you are using is it registered version or some thing else
also pm me
regrads
Fragrance
proteus ccs
Hi Fragance
Tks.
I have installed cloader.zip and follow the instruction inside the loader , but it dont work. The source window display always:
"No source line at PC address [PC=xxx]."
I remember that i used C*C"S PicC Compiler.
Best regards cb30
ccs lcd40x4 proteus
you still did not mension what version of proteus are using altough c and
basic support is only in sp7
Regards
Fragrance
css compiler in proteus
ohh sorry i forget.
The version is sp7.
CCS Isn't supported by Proteus for source code debugging..
ccs c with proteus
Hi ssssss
Proteus dont suport high level debugg with CCS. But low level debug is aviable.
Regards cb30
ccs no proteus
Can you send me a copy of cloader too? What´s your function? I have proteus 6.1 and ccs c 3.094.
thanks.
vccs proteus
my advice is to remove the older sp7 and hunt for v6.1
this will work better
sp7 has inherant problems with some levels of other apps intergrations
v6.1 is also the only one supported by the loaded fragrance posts
as the loader isnt ment for sp7 and uses a different api
this is the third and last time i will say this
DONT MIX PROTEUS LIBRARYS FROM 5.2 to v6.1
it just isnt worth it for the hastle
becouse most dlls wont even say hello to the app
as for the loader it claims on there site it is for 5.2 onward
but in tests i notice it demands an api of a higher version
SO WONT WORK
instead use v6.1 check pm
