Problem with IGBT in Pspice simulation
ocean_f
Newbie level 3
Newbie level 3
igbt in pspice
I try to simulate IGBT with Pspice in different configuration for example buck converter (see the image), but the voltage in the exit is always smaller than the gate voltage 15V despite that supply voltage is 300V. The same story with the half and full bridges and different IGBTs. Where is the problem?
Thanks!
igbt pspice
The problem is, that the gate voltage has to be applied between gate and emitter rather than gate and common ground, as you did. That's why level-shifting and isolating gate drivers are used for high-side switches in real life.
Reactions: augast15
    V
    augast15
exemple simulate pspice igbt
Thanks FvM. God bless you!
