Problem with IAR C Compileur for Z80
rdpdo
Junior Member level 1
iar z80
Hello,
I'm using IAR C Compileur for Z80 (I think it is ICCZ80) and I dont find how to set the adresses of my ROM and RAM. In my case, my ROM is between 0000h and 1FFFh ; and the RAM is between 8000h and 87FFh.
So I'd like that the compileur place the stack in the top of my ram (87FFh) and save the data between 8000/87FF.
When i compile a exemple, the stack is at 0C1FF and not 087FFh...
Thank you very much for your help.
z80 xcl
I'm using IAR C for TLCS900 ... but it should be similar...
For changing memory description you must change .xcl file for your MCU for the linker.
There are interupt vectors, RAM+ROM placement, BIT vars placement and STACK placement etc. described.
rdpdo said:
Hello,
