Problem with HFSS simulation time of center-driven dipole
waltzsu
Newbie level 6
Newbie level 6
I am simulating a center-driven dipole, 1m long. If the radius is larger than 2mm, the running time and simulation results are both acceptable. However, if the radius is 1mm, after a whole night, it is still running!, It is terrible and ridiculous.
Re: HFSS is terrible!
try to use 75 ohm feed and a balun
try to make it lamda/8 in mm thick check the resistivity isnt set too high
HFSS is terrible!
the cylinder is too slim, the aspect ratio of the mesh grid is too large. you'd better draw a prism instead of cylinder.
This sounds to me like an error in the initial mesh.
Give me your .hfss-file, so I can look at it.
