Problem with HFSS Ploting
hohol
Newbie level 2
Newbie level 2
Hi everybody.
I have a question in Plotting in HFSS. The vector result that i become from calculating, I want to plot as its separate arguments in a graph. But I don't know how.
Can you tell me how I could do it?
Thanks!
your query seems to be unclear to me, if you can clarify it in a better way?
Regards.
Hi everybody.
Thanks!
I can't understand your question. I would rephrase it. You might consider posting it to this forum
https://www.edaboard.com/forums/27/
as many readers of that know HFSS - including myself
Even when i know HFSS, i am unable to understand, and understanding of question is the utmost requirement to help.
Sorry for my english.
I try to rephrase it.
In HFSS is a calculator, with wich help you can calculate Field (H or E -Field). The calculated results, you can plot as a 2D-graph (Magnitude, Distance). The calculator gives out the results as a vector. And here is the problem. I want to plot not the whole vector, but his single elements in X, Y and Z direction in dependence of the distance, but i don't know how to separate the vectorelements.
Thanks for help.
