Problem with HB simulation of a FET mixer
khouly
Advanced Member level 5
EGYPT
i am doing a reciver mixer right now ,
the RF =7.3 Ghz the LO= 5 GHz , the IF = 2.3
the prblem is while the HB simulation , i have found that the 2 harmonic of the LO 10 GHz is mixing with the RF 7.3 and produce a signal at 2.7 GHz , which is comparable in power with the desired singal ,
i am using a single trnasistor FET mixer , is there any solution to reduce the interference ,
or i need to space the LO to 6 GHz , i foud the interferer is away
what do u think ?
khouly
Re: Mixer problem
Your best bet is to avoid mixing products near the IF rather than making them smaller.
You should spend a few hours making a spread sheet to predict mixing products and then do a "what if" analysis where you cut and try several IF frequencies as well as high side and low side LO frequencies.
    khouly
Mixer problem
thanks Flatulent
yeah , i retured back to the system analysis again , and i am chinking the IF , i found that 6 GHz for the LO will give good results
the problem is the transistor is wide band , so the 2LO multiplication occur easily
i will try to make a detailed IF analysis and then check
khouly
