smiles
Here is the simple circuit for PIC16f877A that I design , I check the hardware very carefully but when I embed my charged PIC into the circuit, just to test output high and low, it not work ??? I also wonder why the crystal measured by oscillatior has no signal, try to replace another crystal but still the same, do you think that I have to check software also ???
MCLR pin is ok (5V, press button to reset then 0V)
I use CCS compiler, here is .h file
#include <16F877A.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES RC //Resistor/Capacitor Osc with CLKOUT
#FUSES PUT //Power Up Timer
#FUSES NOPROTECT //Code not protected from reading
#FUSES NODEBUG //No Debug mode for ICD
#FUSES BROWNOUT //Reset when brownout detected
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD //No EE protection
#FUSES NOWRT //Program memory not write protected
#use delay(clock=4000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
Hope you help me, thanks so much
#device adc=8
