Problem with designing a S/H amplifier
Karthikeya
Full Member level 1
Problem in S/H amplifier
hi everybody
I have two questions.
1) i am designing a s/h amplifier for 6 bit adc at 1 ghz sampling frequency. i want know which op-amp i can use to obtain this high bw and resolution.
2) i want to know if it is a good idea to convert the fully differential output of s/h to single-ended before giving it to adc. the adc is folding/interpolating type.
looking forward for reply.
thankz in advance.
Re: Problem in S/H amplifier
I answer the first question: using the one stage cascode with gain boost. if the channel length is small, 1G Hz bandwidth differential output can be easily achieved.
I am not sure your second one.
    Karthikeya
