rajaram04
Advanced Member level 3
Hello
i am using a 12v 7Ah battery to run a motor with a fan attached to it. Problem is the decrease in speed or say load handling capacity when I am increasing the wire length. I need to run a 7 mtr length of wire but in 5 mtrs only I am facing the problem . . .Normal LED lamps are working at that end but motor is not working . just I feel a bit vibrations there . . I then connected low voltage motors but they are too not working like the original one . . how to overcome ??
