Problem with creating the test bench in ISE
skycanny
Junior Member level 3
How can i go on?
I have learned ISE of Xilinx for two days,and i do the job as the ISE Quick Start Tutorials. But I failed to continue when creating the test bench,and the hint is "No port signals detected". Where might be wrong? Could you tell me how to continue my work?
Thanks
Re: How can i go on?
Have you described the entities correctly.
If you are using ISE did you configure the signals as input and output?
check these.
B R M
Thanks for your reply
I did not write the entity correctly
Now I have finished the tutorial
