Problem with crc routine for PCIe
balasub
Member level 1
hi,
anyone coded ecrc block used in PCIe?
Re: crc
hi,
thanks for the pointers...
i did create a crc routine..
now the problem is when i send data padded with the crc the receiver is reporting a crc error.
how do i debug this?
i am kind of stuck...
Re: crc
Could it be that the receiver just uses another crc algorithm (different polynomial or additional parameters)?
You have to analyze data with known correct crc to find out the used algorithm. of course it may be also an error in implementation. You can use one of the web crc calculators e. g. linked at wikipedia to check your crc results.
crc
Assuming that you have a data width of 32 in the transmitter and another 8 bits of crc bits padded, can you tell me how you are doing the checking on the receiver side?
Re: crc
hi sree,
here 32 bit crc is used for a data width of 32.
I use a protected code at the receiver side.So i have no visibility.
But this has to comply with the spec hence i guess the problem has to be at my end.
Meaning the way i generate the crc ( i am coding it with respect to the SPEC too).
So just need to debug my code and not sure of a better way to do this.
Added after 46 minutes:
basically i am looking for ecrc/lcrc check for PCIe...
Re: crc
If you feel that the problem might be at your end, have u checked the parallel crc encoder circuit that you are using with a serial LFSR ? if i'm not mistaken, it'll take the same number of clock cycles as the degree of ur polynomial
if u want to, i can post the serial crc code if u provide the polynomial
Re: crc
hi,
i use the 32 bit crc whose polynomial is 04c11db7
crc
module crc (clk,reset,din,checksum);
input clk,reset;
input din;
output [31:0] checksum;
wire [31:0] checksum;
reg [31:0] acc;
always@(posedge clk or negedge reset)
if(!reset)
acc <= 32'b0;
else
begin
acc[0] <= acc[31] ^ din;
acc[1] <= acc[0] ^ acc[31] ^ din;
acc[2] <= acc[1] ^ acc[31] ^ din;
acc[3] <= acc[2];
acc[4] <= acc[3] ^ acc[31] ^ din;
acc[5] <= acc[4] ^ acc[31] ^ din;
acc[6] <= acc[5];
acc[7] <= acc[6] ^ acc[31] ^ din;
acc[8] <= acc[7] ^ acc[31] ^ din;
acc[9] <= acc[8];
acc[10] <= acc[9] ^ acc[31] ^ din;
acc[11] <= acc[10] ^ acc[31] ^ din;
acc[12] <= acc[11] ^ acc[31] ^ din;
acc[13] <= acc[12];
acc[14] <= acc[13];
acc[15] <= acc[14];
acc[16] <= acc[15] ^ acc[31] ^ din;
acc[17] <= acc[16];
acc[18] <= acc[17];
acc[19] <= acc[18];
acc[20] <= acc[19];
acc[21] <= acc[20] ^ acc[31] ^ din;
acc[22] <= acc[21] ^ acc[31] ^ din;
acc[23] <= acc[22];
acc[24] <= acc[23];
acc[25] <= acc[24] ^ acc[31] ^ din;
acc[26] <= acc[25];
acc[27] <= acc[26];
acc[28] <= acc[27];
acc[29] <= acc[28];
acc[30] <= acc[29];
acc[31] <= acc[30];
end
assign checksum = acc;
endmodule
give serial input data and check after 27 clock pulses and let me know if it works.
hope i'm not wrong
    balasub
Re: crc
hi sree,
tried this but i am still not sure...just new to design..
can u post ur testbench for this...
thanks!
