hi all
I am making a rotating light project and need to change its speed by remote control
so I used a TK-19 IR receiver like the one here **broken link removed**
please could someone till me what each pin should be connected to ( signal , Vcc , Ground )
and another question can any IR transmitter like a Tv remote control works for it ?
Thanks in advane
Hi AirForces2050,
I dont no what your problem is! I did find in ca. 15 minutes (in my opinion) the same side wher you your picture has from & it has a clear pinout... **broken link removed**, refer for fig. 2 pls...
K.
Thanks karesz
The problem is that i Have connected the IR receiver (pin 1 ground , pin 2 Vcc and pin 3 is the signal ) to a comparator opamp so it is supposed to give a pulse to the comparator to give a logic 1 and change the speed of the rotating light .
But that doesn't happen and it seems to never receive the signal from the transmitter !
Hali,
your problem is, I think, that its a selective receiver!:-(
You must have some bit stream at 30/33 or 36KHz, not a variable frequency for these devices...
Chek pls the attached datasheet (its similar product from Siemens).
K.
Other possible problem is that your TX-wavelength must be at 950 nm...
"- Available for several carrier frequencies
- Black epoxy resin, daylight filter optimized for 950 nm"
K.
