Problem with connecting Nokia 5200 with PC via Bluetooth
haif
Member level 3
Member level 3
i have phone(nokia5200).its rejet to make connection(via bluetooth)with pc
haif
Re: problem
Do you have Bluetooth software installed on your PC?
Re: problem
First of all, you should make sure, that you actually have the required bluetooth adaptor installed on your pc. Also, check in your phone's bluetooth options whether it is set to invisible.
