Problem with comparator in ramp generator circuit using 741 opamps
Smitasi
India
Hi ppl we have rigged a thyristor gating/firing circuit using opamps 741
the opamp stages include- zcd, integrator, comparator
zcd that detects 0 crossings of 50Hz sine signal from the signal generator
generating a square wave
the is the integrator which gives a ramp output
(4.7K,0.47uF)
After dat is the comparator
Ramp to non inv and votge divider ie ref voltage to inv i/p
From the comparator we are supposed to get pulses based on the comparison b/w the ramp input and the reference input
the ref input is a voltage divider ckt
Till the integrator things were working fyn
but after dat the comparator is not
we are having problems with the kpots(potentiometers) that don't wrk so we eliminated them from the intergator as well
changed breadbords,Ics resistors/capacitors still no use
Could sum1 suggest changes/troubleshooting techniques as 50Hz is not even a high speed signal
Thanks
trigger to ramp schematics
Let me know how are you driving the thyrister gate? A schematic if posted here will speak itself. Good luck
r-firing ckt
In other words, you didn't manage to design a working circuit? Unfortunately, if you assemble a number of electronic parts, there's a high likelihood of selecting a non-operational circuit. So, to get help in this regard, you should post your circuit.
simple op amp ramp circuit 741
plz chk da jpg file
i hav tried installing psice/other sim s/ws bt cudnt
the G, K refer to gate and cathode of the scr
The title of the expt is 'SCR GATING AND FIRING CKT WITH SYNCHRONISED AC POWER SUPPLY'
the signal freq is 50 Hz sine signal from signal genrtr
ramp wave
As i hav vista n my comp many times pspice,multisim etc havnt got instld n my comp
I wud be very grateful if sum 1 helps me wit dis ckt
also 1 mor thng the -ve 1/2 of the integrator o/p wich is traingular wave is gettn clipped but +ve half is perfect
Thanks
design 741 ramp generator
The ramp generator can't work this way. It seems to me, that you designed it from the scratch, without thinking thoroughly about the problem or having a known operational reference design.
Just to mentions two points:
- a 100 Hz sawtooth rather than a 50 Hz triangle waveform is required for symmetrical bipolar phase angle control. If you want to achieve something special, you should clarify the intended trigger and AC waveforms by a diagram.
- an integrator without a reset or a special clipping circuit doesn't give a defined output waveform
Furthermore, a trigger transformer usually gets saturated when driven with a 50 Hz squarewave. Also the power disspiation is probably too high. The common solution is to generate either a single short trigger pulse (of e.g. 20 us duration) or a trigger burst. This is particularly required considering the rather high trigger current of power thyristors and triacs.
I suggest to study the operation of state-of-the-art trigger generators, e.g TCA785, as a reference.
circuit of ramp generator using 741
Hey it's not a self generating ramp generator
to produce trigeering in sync wit da ac supply
da 0 crosings can be used as ref
hence we r using a zcd integrator and comparator so that only at a particular voltage and 4 small time period pulses r generated
ramp generator with opam
Yes, but your circuit doesn't manage it. I made my suggestion.Good luck!
