Problem with code for converting 24bits from A/D and displaying them on an LCD
veioloko
Member level 1
Member level 1
Brazil
Hello everybody
I´m trying to convert an 24bits from a/d and display it into an lcd.
First i´m converting de 24bits to decimal, and after i add 0x30(ascii)..
however i´m having a problem
the value on the display sometimes it´s incorret, not number. it happens only where i will place X
000yxx00,
When y>=4 xx has character that is not a number.
Does anyone knows why?
char int_ascii(unsigned long int x){
unsigned char a, valor[8],cBuff[17];
unsigned long int var_aux;
valor[8]='\0';
valor[0] =  x / 10000000; //atribui o valor ASCII a dezena de milhar
var_aux = x - (valor[0] * 10000000) ;
valor[0]= valor[0]+'0';
valor[1] = var_aux / 1000000; //atribui o valor ASCII a milhar
var_aux -= valor[1] * 1000000;
valor[1]= valor[1]+'0';
valor[2] = var_aux / 100000; //atribui o valor ASCII a milhar
var_aux -= valor[2] * 100000;
valor[2]= valor[2]+'0';
valor[3] = var_aux / 10000; //atribui o valor ASCII a milhar
var_aux -= valor[3] * 10000;
valor[3]= valor[3]+'0';
valor[4] = var_aux / 1000; //atribui o valor ASCII a milhar
var_aux -= valor[4] * 1000;
valor[4]= valor[4]+'0';
valor[5] = var_aux / 100; //atribui o valor ASCII a centena
var_aux -= valor[5] * 100;
valor[5]= valor[5]+'0';
valor[6] = var_aux / 10; //atribui o valor ASCII a dezena
var_aux -= valor[6]* 10;
valor[6]= valor[6]+'0';
valor[7] = var_aux % 10  + '0'; //atribui o valor ASCII a unidade
return ((unsigned char)valor);
		while(!(AIPOL&0x20)) {}             // Wait for conversion
		result=unipolar();                 // Save Results
    sprintf(cBuff,"Med: %s",int_ascii(result));
     lcd_env_inst(0X80);
     lcd_puts(cBuff);
Re: 24bits ascii lcd
Replace your int_ascii with this itostr
void itostr(unsigned int val, unsigned char *result)
	static char buf[12] = {0};
	int i = 10;
	for(; val && i ; --i, val /= 10)
			buf[i] = "0123456789"[val % 10];
	strcpy(result,&buf[i+1]);
Hello
thanks for the help,however i used another code,that i use the function : for....do the same as i posted but now it works,i don´t know why
hey i had the same problem.......i did try what u have written but it consumes a lot of space i think 1K of memory ...try this it consumes only 0.1K....
and try adding 48 its 30 in hex....
the prog working simple maths....a floating point no is generated by dividing it by 10...since it is converterted to int the last digit is removed....when u multiply it by 10 and subtract it from the original number u get the last single digit...
the process continues...how is the code....do msg me if it helps..
ok why 10 in the FOR loop....the max digits by a 32bit hex number is a 10 digit decimal number...
void main ()
int f[10];
int32 c,e;    ///it means 32 bit number
while(1)
c = 123456789;          ////my number is 32 bit u can change that(for testing)
for(j=0;j<10;j++)
e = c / 10;
f[i] = c-(10*e);
f[i]=f[i]+48;               ////48==30 in hex....(may be this is ur problem)
c=e;
