LaichiKang
Newbie level 1
chipcon cc1000 problem
Me and my partner are working on a Tranceiver Module (Chipcon CC1000). We use the Hynix GGMS81C1408 as our microcontroller. The RX side was powered by a USB port (data through RS232) while the TX side was powered with voltage regulator. Our module uses NRZ coding. The TX works fine because the signal interpreted from the oscilloscope was in accordance to the data we sent. Operating frquency is 443MHz. Software used is ISM Linker while emulator used is GMS800 for Hynix.
Problem: The RX received a different sort of signal which is different from the TX. According to the Chipcon datasheet, a DC balanced preamble is needed. The pattern of the preamble is "0101010101................" What's a preamble? How does it work? PLz help anybody..................
