Problem with Cadence as Spectre simulator opens several minutes
ahmed tolba
Newbie level 6
Newbie level 6
Egypt
Hi all,
I'm using cadence to design a cct, I drew the schematic but when I start the simulator (spectre) it takes
too long to open .... I don't know what the problem is?? can any one help??
Re: help with cadence
if your cct has transistors tou can check if you install PDK in right way or not
help with cadence
What's your linux version? It has relation witn linux
Hi jamesfeng1981,
sorry for replying too late.........I'm working on Linux 10.2
help with cadence
There might be problem with license settings/server, and it might be taking too long to checkout a license...
help with cadence
my be it the problem of you computer.
I know why it is ...If i am right the slownessis only for the first time after u start ur icfb.
This is because cadence framw work doesnot load everything when it starts. It loda sonly the default things as and when required it loads the reqd things.
If u r working on fast machines with heavy RAM then you may not notice the slowness, because the time it takes is veryisignificant. But if u open on ur local machine then u will see the issue of slowness.
Thanks
Sriramachandra
the processor is 1.86GHz, and RAM is 512M
however I think to open the simulator it shouldn't take that much time(few minutes!!?)
software and hardware incompatibility
what's the version?
Maybe you don't have MMSIM60 installed yet
ahmed tolba said:
Hi all,
what's the version of Cadence IC and what kind of Linux OS?
