problem with cadence 16.3 license installation
m_kavith
Member level 3
Member level 3
chennai
i have installated cadence16.3 version. 1st i installed license manager. then i installed product. after that i start the progam. it said "no allegro orcad license file not found".plz guide me how to run the program?. where to find the license file.
I've installed it many times and never had an issue, it always detects it automatically as far as I remember (maybe I've been lucky). Anyway, I found an installation guide online, if you follow the steps in that it should install. If not I'd suggest contacting cadence would be your best bet.
Cadence Installation Guide
Reactions: alexxx
    alexxx
Can you please check if you have following environment variable set
CDS_LIC_FILE
and it's value should be 5280@licenseservername
You can set the direct under windows environment variable or by using cadence license manager client setup utility
I assume your license server is up and running and you have valid license for OrCAD PCB Editor version 16.3
