Problem with C++ code for image file reading for processing
CMOS
Advanced Member level 3
USA
C++ File Reading Problem
I am trying to read PGM (P5-Binary) Image file for processing using the following C++ code. The problem is that the bytes are not read properly from input file and so the output file contains junk characters only.
The code right now copies image data from one file to another. No processing is done. Can someone point out where the problem is?
//---------------------------FREE IMAGE---------------------------------
void FreeImage(int ***fimage, int N)
	for(int i=0; i<N; i++)
		delete (*fimage)[i];
	delete *fimage;
//----------------------------READ IMAGE--------------------------------
void ReadImage(char fname[], int ***fimage, int& M, int& N, int& Q)
	int i, j;
	char d;
	char header [100], *ptr;
	ifstream ifp;
	ifp.open(fname, ios::in);
	if (!ifp)
		cout << "Can't read image: <" << fname << '>' << endl;
		getch();
		exit(1);
	ifp.getline(header,100,'\n');
	if((header[0]!='P') || header[1]!='5')   /* 'P5' Formay */
		cout << "Image <" << fname << "> is not in binary PGM 'P5' format." << endl;
		getch();
		exit(1);
	while(header[0]=='#')
	M=strtol(header,&ptr,0);
	N=atoi(ptr);
	Q=strtol(header,&ptr,0);
	*fimage = new int* [N];
	for(i=0; i<N; i++)
		(*fimage)[i] = new int[M];
	for(i=0; i<N; i++)
		for(j=0; j<M; j++)
			d = ifp.get();
			(*fimage)[i][j]= (int)d;
//----------------------------WriteImage--------------------------------
void WriteImage(char fname[], int **fimage, int M, int N, int Q)
	int i, j, c;
	ofstream ofp;
	ofp.open(fname, ios::out);
	if (!ofp)
		cout << "Can't open file: " << fname << endl;
		getch();
		exit(1);
	ofp << "P5" << endl << "# Comments" << endl;
	ofp << M << " " << N << endl;
	ofp << Q << endl;
	c=0;
	for (i=0; i<N; i++)
		for (j=0; j<M; j++)
			ofp << (char)fimage[i][j];
	ofp.close();
	cout << "\nFile <" << fname << "> saved.";
//-----------------------------Main-------------------------------------
void main(void)
	int i, j;
	int N, M, Q;		// N=Rows   M=Cols   Q=GreyLevels
	int **fimage;		// int **I 2-D Array of Image
	char infile[40];        // name of input file
	char outfile[40];	// name of output image file
	cout << "Enter name of *.pgm INPUT image file: ? ";
	cin  >> infile;
	cout << "Enter name of *.pgm OUTPUT image file: ? ";
	cin  >> outfile;
	ReadImage(infile, &fimage, M, N, Q);	// Memory created for fimage
	WriteImage(outfile, fimage, M, N, Q);	// Save image to file
	FreeImage(&fimage, N);           	// Clear memory
If you are working with binary file using ifp.getline(header,100,'\n'); looks inappropriate .
chnage to buffer read member function .
Re: C++ File Reading Problem
I think you haven't understood the problem. The P5 PGM file looks somewhat like this
P5
# Created by IrfanView
20 20
255
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ€ÿÿÿÿÿÿÿÿ€ÿÿÿÿÿ
Where,
P5 -> Format specifier
# xxxx -> Comments
20 20 -> Size of image i.e. M x N pixels
255 -> No. of grey levels
xxxx -> raw pixel data
Thats means P5 is not completely a binary file. The first four lines contain numbers in ASCII.
The first four lines are read correctly and also stored as they are in the output file. But the Binary data which starts from 5th line appears as junk and no where related to input file.
I never sure in what i said but there is piece of truth
that you can take into account .
have a lool to https://www.cplusplus.com/ref/iostream/ifstream/open.html
https://www.cplusplus.com/ref/iostream/istream/get.html
Once you have opened file without ifstream::binary it will format the input from file . In your example you first try to read few lines of text and then trying to read it by get() member function . But get() will read according to file open mode and also formats input .
You can test this as - make a printf of byte value read from file and compare it to the value of character in file read from your famous hexeditor - you should see there differences .
I did not check the whole code but at least this issue looks suspicious .
OK, I found the problem. I just changed ifp.open(fname, ios::in); to ifp.open(fname, ios::binary); Same was done with ofp also
Rest all is same. It works now.
