WALA
Newbie level 1
Hello, I am working on estimating wimax system using pilots, i applied the OFDM block and made the pilot insertion based on the block arrangement but the problem am facing is that the BER stays in its max. value it doesn't change with the SNR . i have tryed the comb type with interp, the insertion in both time and freq with using interp2, but i have the same problem.
Please help me pleas please
this is my code. i have another problem with the graph of mean square error please help me
N = 128; % fft size
Pil = N/4; % 32
S = N-Pil; % number of data subcarriers 112
nIteration = 500;
L = 30;
GI = N/4; % 32
Ep = 2;
SNR_V = [0:3:27];
ber = zeros(1,length(SNR_V)); % initializing bit error rate
M = 2; % modulation object
% Generating data
T_Data=randint(N,1,M); % 128 1
% modulating data
mod_data = pskmod(T_Data,M);
% serial to parallel conversion
par_data = reshape(mod_data,8,16); % 8 16
Ip=1:4:N;
Is = setxor(1:N,Ip);
% pilot insertion
pilot_ins_data=[];
for Ip=1:4:13
pilots= Ep*par_data(:,Ip);
xp=[pilots par_data(:,Ip+1) par_data(:,Ip+2) par_data(:,Ip+3)];
pilot_ins_data=[ pilot_ins_data xp];
end
pilot_ins_data; % 8 16
PilotData=reshape(pilot_ins_data,8*16,1); % 128 1
LocPilot= [ PilotData(1:8,1); PilotData(33:40,1); PilotData(65:72,1); PilotData(97:104,1) ]; % Locations of pilots after reshape 32 1
% fourier transform time doamain data and normalizing the data
no_of_error=[];
ratio=[];
for i = 1 : length(SNR_V)
SNR = SNR_V(i)
for k = 1 : nIteration
IFFT_data = ifft(PilotData,N); % 128 1
% addition cyclic prefix
Cylic_add_Data = [IFFT_data(N- GI + 1 : N); IFFT_data]; % 96 1
% generating random channel coefficients
h(1:L,1) = random('norm',0,1,L,1) + ...
j * random('norm',0,1,L,1);
h = h./sum(abs(h)); % normalization 30 1
ChannEffect = filter(h,1,Cylic_add_Data); % channel effect 160 1
% adding awgn noise
Signal_Noise = awgn(ChannEffect , SNR - db(std(ChannEffect))); % normalization to signal power
Cyclic_pre_Rem = Signal_Noise(GI+1:N+GI); %cyclic prefix removal
FFT_recdata =fft(Cyclic_pre_Rem,N); % freq domain transform 128 1
% LS Estimation & 1D interpolation
F = exp(2*pi*sqrt(-1)/N .* meshgrid([0:N-1],[0:N-1])...
.* repmat([0:N-1]',[1,N])); % 128 128
Tpilot= LocPilot;% transmitted pilots 32 1
Rpilot=[ FFT_recdata(1:8,1); FFT_recdata(33:40,1); FFT_recdata(65:72,1); FFT_recdata(97:104,1) ]; % received pilots 32 1
% Hpls=inv(diag(LocPilot))* Rpilot; % 32 1
Ipp=[ 1:8 33:40 65:72 97:104 ];
G = (Ep * length(Ipp))^-1 ...
* ctranspose(sqrt(Ep)*diag(Tpilot)*ctranspose(F(1:L,Ipp))); % 30 32
Hpls = G*Rpilot; % 30 1
Hh=interp(Hpls,4); % 120 1
Demod_Data = pskdemod( FFT_recdata./(fft(Hpls,N)),M); %demodulating the data 128 1
% or Demod_Data = pskdemod( (fft(Hh,N)./(fft(Hpls,N)),M);
DataEstiRec=[ Demod_Data(9:32,1); Demod_Data(41:64,1); Demod_Data(73:96,1); Demod_Data(105:128,1) ];
DataTra=[ T_Data(9:32,1); T_Data(41:64,1); T_Data(73:96,1); T_Data(105:128,1) ];
[nErr bErr(i,k)] = symerr(DataEstiRec , DataTra);
ms_error_mat=mean(((abs(h-Hpls))/abs(h)).^2);
for v=1:16
if(ms_error_mat(v)~=0)
ms_error=ms_error_mat(v);
end
end
ls_mse(k,i)=ms_error;
ls_mse_ave=mean(ls_mse);
semilogy(SNR,ls_mse_ave,'--ro')
grid on
end
end
% plotting the result
xlabel('SNR in dB')
ylabel('mean squared error')
title('PLOT OF SNR V/S MSE FOR AN OFDM SYSTEM WITH LS ESTIMATOR BASEDRECEIVERS')
figure(2)
semilogy(SNR_V,mean(bErr'),'--or','linewidth',2);
hold on;
EbN0Lin = 10.^(SNR_V/10);
theoryBer = 0.5.*(1-sqrt(EbN0Lin./(EbN0Lin+1)));
semilogy(SNR_V,theoryBer,'--ob','linewidth',2);
legend('simulated','theoritical')
grid on
xlabel('SNR');
ylabel('BER')
title('Bit error probability curve for BPSK using OFDM');
