abouras
Member level 2
![Member level 2](/styles/images/ranks/dlevel2.gif)
bascom dtmfout
I am using BASCOM-AVR compiler ver 1.11.7.3 and when a DTMFOut command is executed the program starts from the beggining. I thought that there was something with software-hardware-frame stack but changing the values to maximum possible returned no result
Even the MCSElec example doesn't work!!!!!
When i used ver 1.11.6.7 everything worked normally
Is there really a problem with that version or am i doing something wrong????
