sriblue7
Member level 1
Hi! i am using an atmega16L microcontroller for processing the input from ht-12D and based on this input appropriate pins of microcontroller are made high.I have used port B as input and ports A and C for output.I have set the fuse bits as lfuse=0xFF and hfuse=0xC9 for using an external 8Mhz crystal and to use port C as i/o pins.I use parallel port programmer(dapa).I use this setup for making the receiver part of my robot.
The problem is i am getting the desired output only if i switch off and switch on my power supply(i am not getting my output immediately).What could be the problem?
