asimraufawan
Member level 2
HI All!
A 2.5KW converter input 120 VDC & output 220-230 VAC.
The problem is when i run the converter under full load (11 Ampere) it gives 225 VAC output volt at 118-120 VDC input, after one hour it gives 222 VAC at output
& after two hours it gives 220 V AC at output then after sometime it comes to 219VAC & then the voltages starts fluctuating between 218-234 VAC, the max temperature rise is 65 degree Celcius which is under limit.
Why the output is not stable & what should i do to remove this bug.
It works fine at 10.2 Ampere (226 VAC at output)
the rated is 11 Ampere.
Please help
Thanks.
Please help
Thanks.
