Problem with Amplifier Circuit
Tutan Debnath
Newbie level 1
Newbie level 1
Hi All,
i am trying to make an amplifier circuit(Speaker Using Transistor BD139). Now calculating Q parameters( I_CQ & V_CEQ) problem with selection of "Beta" From the datasheet I can choose it but Datasheet has the graph(hFE Vs I_C) for V_CE=2V, But my calculating V_CEQ=5.5V. So how can I choose My Beta for Design.
Here the Datasheet Link...
As a first guess, you can assume same B for 2V and 5V Vce. Type and temperature variation will be much larger (at least 2:1) than the rather small voltage dependency.
hfe is dependent on Ic & to some extent on VCE. So,it may be almost near to the same value at same value of Ic.
It's just a change of 3.5 V.
You can find Ic vs Vce plot in data-sheet.You have hfe vs Ic.
If you want,you could plot the graph for different values of Vce,but i don't think it would be worth it for 3V change.
