icaroM98
Newbie
Hello,
I'm trying to simulate an integrator circuit in LTspice, but it doesn't work.
By the transfer function, the circuit behaves like an integrator and like a low-pass circuit.
When I input a square wave, the desired input signal should be a triangle wave, but the output that the LTspice shows is a constant saturated 12V signal.
What could be wrong with this simulation? I have attached the simulation images.
Thank you very much in advance.
