rohansinha2000
Member level 2
sir i made a clock with 4 digit 7 segment multiplex with a big digit display.it works but problem is in the display .bkz the digit segment is not turned off properly to display a digit. as example to display 3 we need just 5 segment to turned on.but rest of the 2 also turned on dimly. i used 4 bc557 for 4 digit only with 12 volts for digits. and 7 segments are connected with at89c2051 with 330 ohms. the bc557 is connected with at89c205 with 10k resistance. each segment contain green 4 leds. plz help me out from that problem to display digit clearly.
