Problem with 10W SMPS design as it fails EMC test
eem2am
Banned
Hello,
I work in a company that makes LED lighting products that run off car batteries at about 13.5V and we are in Washington.
There are 5 members of staff in the Electronics Dept.
Eighteen months ago, the Electronics Dept was asked to design and build a 10W SMPS which would power a series string of LEDs at 350mA.
We still have failed to successfully do this –mainly because we are failing the EMC test.
The PCB must have dimensions of 84mm by 15mm, due to the enclosure in which it must fit.
-There are two mounting holes of diameter 4.5mm which occur in the longways midline of the PCB at each end, each whose centre is 15mm from the respective short edge of the rectangular PCB.
-obviously there are two cylindrical pillars coming up from the enclosure which “mate” with these mounting holes.
So far we have done double-sided PCB designs.
The enclosure in which this PCB is to be fitted is actually a heatsink for the LEDs.
There is only 5mm of clearance above, and 5mm clearance below the PCB so tall components cannot be used.
Anyway, the problem is that we cannot fit in the sufficient amount of EMC filtering inductors and capacitors that would be needed to get this SMPS to pass the EMC test.
Have we reached the “boundary of impossibly small size” for a 10W SMPS here?
Is this beyond the wit of human-kind?
So far we have implemented continuous mode boost converters and these have failed the EMC.
Does any reader know of an “EMC quiet” topology that would allow us to be able to fit it into this small PCB ?
I am wondering if a transformer isolated push-pull converter would be more quiet with its LC output filter?……though having said that, the input current does have a discontinuity as the primary side “swaps coils” (other transistor starts conducting).
One bad EMC problem with the continuous mode boost is that the Schottky diode has capacitance and conducts a very high amplitude current spike through the MOSFET when the MOSFET turns ON……therefore, I am wondering if discontinuous mode boost should in fact be more “EMC quiet” in spite of its higher peak currents?
The other day, I was in the works conveniences and I overheard two senior members of staff in the organisation saying how useless our Electronics Dept was that five of us could not design a 10W Switch mode power supply in eighteen months.
Any tips on how to “design small” like this and pass EMC greatly appreciated.
design small power smps
Why did you choose push-pull topology for 10watts? I would rather use simple flyback. It's smaller, no need for driving 2 transistors etc. You can use more space for filtering instead for transistor. I would select controller with integrated switch.
Discontinuous mode converter with proper filtering can be as quiet as continuous mode with usual filtering. Very crucial is PCB design - especially short traces from bulk capacitor to power MOS. There is large dI/dt. And also short traces on secondary side from rectifier to filtering capacity and back to secondary. Moreover area occupied by this parts should be as small as possible (close to each other). Traces shouln't be an antenna (small area).
Read some application notes from TI site and Unitrode. Look at the Application journal (I think this article is from 2004, 2005).
10 w smps
If you prefer to discuss the problem on a general level, I would simply mention, any topology can comply EMC regulations.
For a detailed discussion, you may want to tell some measurement results.
mosfet emc
Well FvM is right , u need to share measurement results or the problem frequencies . Any way for 10W may be flyback is good choice , again for his too u need to take care all the dv/dt and di/dt. Take care specially of transformer design for EMC point of view.
emc test pcb application note
Hi eem2am,
The group is right. We need some more data to really help. Is the problem broadcasted or conducted? What are the frequency ranges where the problems are? How many db are you over? Things like this would help point some answers in the right direction.
Best
dfullmer
