[51] problem while compiling nuvoton79e855
Any reason why you don't tell the reported error?
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?MCP3302_READ?MAIN
*** ERROR L107: ADDRESS SPACE OVERFLOW
    SPACE:   DATA
    SEGMENT: _DATA_GROUP_
    LENGTH:  001CH
Program Size: data=120.1 xdata=0 code=4393
Target not created.
That's a popular fault in C51 programming which can be usually overcome by well considering to which class each data object can be assigned, e.g. shifting more objects to code and xdata.
I can't test the project due to missing include files.
At the main.c file there is not declared the prototype for the funcion MCP3302_Read().
guys this my code in 89s51 but didn't how get it into nuvoton and how to access xram of nuvoton
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
#include <n79e855a.H>
#include <stdio.h>
#include <string.h>
sbit SET = P1^0;
sbit INC = P1^1;
sbit LED = P3^7;
sbit CLK = P1^4;
sbit DOUT = P1^5;
sbit DIN = P1^6;
sbit CS = P1^7;
code const unsigned int presetValues[] = {5,10,15,20,25,30,40,50,60,70,80,90,100,125,150,175,200,225,
                       250,275,300,325,350,375,400,425,450,475,500,525,550,575,600,
                       625,650,675,700,725,750,775,800,825,850,875,900,925,950,975,1000};
char mask[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
char mask_dp[] = {0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF};
unsigned int setValue = 0, i = 0;
char myFlags  = 0;
char setFlag = 0;
char incrementOrDisplayToggleFlag = 0;
char blink = 0;
double adcValue = 0.0, fTen = 10.0, fHundred = 100.0, fThousand = 1000.0, prevAdcValue = 0.0;
char display[4] = {0, 0, 0, 0};
char ten = 10, hundred = 100, blinkCount = 0, counter = 0;
unsigned int thousand = 1000;
char select = 0;
int sprintf (char *buffer, const char *fmtstr, double s);
void Delay_us(unsigned int us_count);
void Delay_ms(unsigned int ms_count);
void Display(void);
void Display2(double s);
void Delay_us(unsigned int us_count) {
        while(us_count!=0)
                us_count--;
void Delay_ms(unsigned int ms_count) {
        while(ms_count!=0)
                Delay_us(112);   //delay_us is called to generate 1ms delay
                ms_count--;
void InitTimer1() {
    TMOD = 0x10;
    TL1  = 0x00;
    TH1  = 0xEE;
    TR1  = 1;
    ET1 = 1;
    EA = 1;
void InitTimer0() {
    TMOD |= 0x01;
    TL0  = 0xFE;
    TH0  = 0x4B;
    TR0  = 1;
    ET0 = 1;
void timer0_ISR (void) interrupt 1 {
    if(TF0) {
        if(++counter == 8) {
           TR1 = ~TR1;
           if(TR1 == 0) {
                P3 = (P3 & 0xF0);
                blinkCount++;
                if(blinkCount == 4) {
                      blinkCount = 0;
                      TR0 = 0;
                      TL1  = 0x00;
                      TH1  = 0xEE;
                      TF1 = 0;
                      incrementOrDisplayToggleFlag = ~incrementOrDisplayToggleFlag;
                      TR1 = 1;
           counter = 0;
       TL0  = 0xFE;
       TH0  = 0x4B;
       TF0 = 0;
void timer1_ISR (void) interrupt 3 {
    if(TF1) {
        //Enter your code here
        P3 = P3 & 0xF0;
        switch(select) {
            case 0:
                 P2 = display[0];
                 P3 = (P3 & 0xF0) | 0x08;
                 break;
            case 1:
                 P2 = display[1];
                 P3 = (P3 & 0xF0) | 0x04;
                 break;
            case 2:
                 P2 = display[2];
                 P3 = (P3 & 0xF0) | 0x02;
                 break;
            case 3:
                 P2 = display[3];
                 P3 = (P3 & 0xF0) | 0x01;
                 break;
        select++;
        if(select == 4) {
            select = 0;
        if(incrementOrDisplayToggleFlag) {
            if((setValue >= 0) && (setValue < ten)) {
                 if(select == 1)select = 0;
            else if((setValue >= ten) && (setValue < hundred)) {
                 if(select == 2)select = 0;
            else if((setValue >= hundred) && (setValue < thousand)) {
                 if(select == 3)select = 0;
        TL1  = 0x00;
        TH1  = 0xEE;
        TF1 = 0;
void Display1() {
            display[0] = mask[setValue];
            display[0] = mask[setValue % ten];
            display[1] = mask[setValue / ten];
            display[1] = mask[((setValue / ten) % ten)];
            display[2] = mask[setValue / hundred];
     else if(setValue >= thousand) {
            display[2] = mask[((setValue / hundred) % ten)];
            display[3] = mask[setValue / thousand];
void Display2(double s) {
                 unsigned int befDec = 0, aftDec = 0;
                 befDec = s;
                 aftDec = (s - befDec) * 100;
                 if((adcValue >= 0.0) && (adcValue < 1.0)) {
            display[3] = mask_dp[0];
            display[2] = mask[aftDec / hundred];
            display[1] = mask[(aftDec / ten) % ten];
            display[0] = mask[aftDec % ten];
                 else        if((adcValue >= 1.0) && (adcValue < fTen)) {
            display[3] = mask_dp[befDec];
     else if((adcValue >= fTen) && (adcValue < fHundred)) {
            display[3] = mask[befDec / ten];
            display[2] = mask_dp[befDec % ten];
            display[1] = mask[aftDec / hundred];
            display[0] = mask[(aftDec / ten) % ten];
     else if((adcValue >= fHundred) && (adcValue < fThousand)) {
            display[3] = mask[befDec / hundred];
            display[2] = mask[(befDec / ten) % ten];
            display[1] = mask_dp[befDec % ten];
            display[0] = mask[aftDec / 100];
     else if(adcValue >= fThousand) {
            display[3] = mask[befDec / thousand];
            display[2] = mask[(befDec / hundred) % ten];
            display[1] = mask[(befDec / ten) % ten];
            display[0] = mask_dp[befDec % ten];
double MCP3302_Read() {
       char i = 0;
       unsigned int adcVal = 0, mask = 0x800;
       CS = 1;
       Delay_us(5);
       CS = 0;
       Delay_us(5);
       CLK = 1;
       Delay_us(5);
       CLK = 0;
       Delay_us(5);
       DOUT = 1;
       CLK = 1;
       Delay_us(5);
       CLK = 0;
       Delay_us(5);
       DOUT = 0;
       CLK = 1;
       Delay_us(5);
       CLK = 0;
       Delay_us(5);
       CLK = 1;
       Delay_us(5);
       CLK = 0;
       Delay_us(5);
       CLK = 1;
       Delay_us(5);
       CLK = 0;
       Delay_us(5);
       CLK = 1;
       Delay_us(5);
       CLK = 0;
       Delay_us(5);
       for(i = 0; i < 12; i++) {
             adcVal >>= 1;
             if(DIN) {
                 adcVal = adcVal | mask;
             CLK = 1;
             Delay_us(5);
             CLK = 0;
             Delay_us(5);
       CS = 1;
       return (double)(adcVal & 0x0FFF);
void main() {
     P0 = 0x00;
     P1 = 0x43;
     P2 = 0x00;
     P3 = 0x00;
     Delay_ms(200);
     InitTimer1();
     while(1) {
            adcValue = MCP3302_Read();
            if(!SET) {
                 Delay_ms(50);
                 while(!SET);
                 setFlag = ~setFlag;
                 if(setFlag == 0){
                      InitTimer0();
                      blinkCount = 0;
                      Display1();
                      Delay_ms(3000);
            if(setFlag) {
                  if(!INC) {
                       Delay_ms(50);
                       while(!INC);
                       setValue = presetValues[i++];
                       if(i == 49)i = 0;
                  incrementOrDisplayToggleFlag = 1;
                  Display1();
            else if(!setFlag) {
                   if(!INC) {
                       Delay_ms(50);
                       while(!INC);
                        Display1();
            else if(!incrementOrDisplayToggleFlag)
                        Display2(adcValue);
            if(adcValue > setValue)LED = 1;
            else LED = 0;
help to develope code for i2c
i developing project need to save the set value but didn't how to program in nuvoton n79e855 help me pls, help to code for i2c
