lorempa
Newbie level 1
Hi guys,
I'm a noob trying to become more and more expert
The project I'm trying to design should be able to correlate (or auto-correlate) a binary signal (i.e. an arbitrary binary sequence) and output the correlation coeffs using a 16-bit word.
All was coded under Verilog and I'm using Xilinx Spartan-6 as development board to run it.
So, now to the wear behavior.
When trying to test it sending some bytes from HTerm through serial port everything worked fine till the register which kept all the bits doesn't exceed the value of 256 bit (i.e. 16 bytes). When trying to correlate a larger sequence , like 512 bits, the values are inconsistent!!
A last clarification: the method makes a circular right shift of 1 bit of the entire sequence, then autocorrelate the signal (using XNOR and counting the numb of 1s and 0s and then finally summing the 2 sums)
Any idea? There's maybe some kind of limitation in the register width in Verilog/Xilinx FPGA?
BTW, everything works very fine when simulating the 32 bytes (or even more) testcase with ISim!
Here is the core module:
Cheers, LoREmpa
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 `timescale 1ns / 1ps ////////////////////////////////////////////////////////////////////////////////// // Company: // Engineer: // // Create Date: 10:52:45 05/18/2011 // Design Name: // Module Name: magic_box16bit // Project Name: // Target Devices: // Tool versions: // Description: // // Dependencies: // // Revision: // Revision 0.01 - File Created // Additional Comments: // ////////////////////////////////////////////////////////////////////////////////// module magic_box16bit #(parameter NBIT = 512 // # bits in the sequence ) (input clk, input reset, input [NBIT-1:0] seq2shift, input start_magic, output [7:0] coeff, output reg end_tick ); // symbolic state declaration localparam [1:0] idle = 2'b00, corr = 2'b01, split = 2'b10; // signal declaration reg [1:0] state_reg, state_next; reg [9:0] c_reg, c_next; // counts up to 512 bits reg [NBIT-1:0] b_reg, b_next; reg [15:0] bb_reg, bb_next; reg [1:0] s_reg, s_next; integer i; reg signed [15:0] sum; reg [15:0] ones, zeros; reg [NBIT-1:0] tmp; reg [NBIT-1:0] seq_ref; reg [7:0] c; // body // FSMD state & data registers always @(posedge clk, posedge reset) if (reset) begin state_reg <= idle; c_reg <= 0; b_reg <= 0; s_reg <= 0; bb_reg <= 0; end else begin state_reg <= state_next; c_reg <= c_next; b_reg <= b_next; s_reg <= s_next; bb_reg <= bb_next; end always@* begin state_next = state_reg; end_tick = 1'b0; sum = 0; zeros = 0; ones = 0; tmp = 0; c = 0; c_next = c_reg; b_next = b_reg; s_next = s_reg; bb_next = bb_reg; case (state_reg) idle: begin if(start_magic) begin b_next = seq2shift; state_next = corr; c_next = 0; end end corr: begin if(c_reg == NBIT) state_next = idle; else begin b_next = (b_reg >> 1) | (b_reg << 511); //right circular shift //b_next = {b_reg[0], b_reg[NBIT-1:1]}; // barrel shifter of 1 bit left! c_next = c_reg +1; tmp = b_reg~^seq2shift; for (i=0; i<NBIT; i=i+1) ones = ones + tmp[i]; zeros = NBIT - ones; sum = ones - zeros; bb_next = sum; state_next = split; s_next = 0; end end split: begin if (s_reg == 1) begin c = bb_reg[7:0]; s_next = s_reg + 1; end_tick = 1'b1; state_next = corr; end else begin c = bb_reg[15:8]; s_next = s_reg + 1; end_tick = 1'b1; end end endcase end assign coeff = c; endmodule
Cheers, LoREmpa
