Creese
Hi all
My tools environment is : installv3.0 , scl10.9.3 vcs2012, nanosim2012
I have already run vco of nanosim examples, it's passed.
But when I run NS-VCS in tutorial of nanosim examples, there was a error after "simv +COMPILE" command:
***** Warning: Stacksize soft limit 10240 K is too small, we prefer more than 60000 K,
please use csh command " limit stacksize 60000 " to set it.
Chronologic VCS simulator copyright 1991-2013
Contains Synopsys proprietary information.
Compiler version H-2013.06; Runtime version H-2013.06; Oct 1 04:06 2013
| NanoSim Version F-2011.09-SP2 |
| SN:20120217-linux |
| Machine Name: localhost.localdomain |
| Copyright (c) 2011 Synopsys Inc., All Rights Reserved. |
Built by nsmgr on Fri Feb 17 01:36:52 PST 2012
Tue Oct 1 04:06:29 PDT 2013
The 32-bit version of the simulator is running.
Initializing system messages ...
Initializing system messages took 0.010 s
ERROR:NanoSim:0x3110140fRODUCT LICENSE NOT AVAILABLE FOR "nanosim"
Error-[MSV-INTERFACE-ERROR] Mixed-Signal Interface Error
Internal Error in Mixed-Signal cosim flow.
' aborting ...
Segmentation violation - signal 11
Please send the following information to Synopsys support along with a testcase.
| SN:20120217-linux |
"23528692 15709216 18854074 18860655 18918347 134601680 -1230068510 1780551 1783080 134595597 18789813 31254150 31239975 22259008 20518899 18910427 18871650 18889638 134617432 134621030 -1226734291 -1226408596 -1226402095 -1231643846 134558289 -1231719711 -1231718844 -1230174839 -1229983258 134558456 4050588 "
Can you give some method to solve this problem? thanks very much.
| SN:20120217-linux |
' aborting ...
| SN:20120217-linux |
