scscsc
Junior Member level 2
problem when adding stripe :antenna segment
Hi everyone,
I have a problem when adding stripes in my design. I want to add four vertical stripes. The first one works. The second and third one are shorter than the value I set. The fourth one is cut into two segments. There are warnings like this (ex. fourth stripe).
The power planner cannot find target for the antenna segment at 19.30 48.10. Please use sroute to connect them.
The power planner cannot find target for the antenna segment at 13.30 55.40. Please use sroute to connect them.
It seems that the placement of my modules affects the stripes. Anyone has an idea of the reason? can I add stripes first before the placement?
Here is my script for stripes adding
addStripe -block_ring_top_layer_limit M7 -max_same_layer_jog_length 6 -padcore_ring_bottom_layer_limit M5 -number_of_sets 1 -stacked_via_top_layer AP -padcore_ring_top_layer_limit M7 -spacing 2 -merge_stripes_value 2.5 -layer M6 -block_ring_bottom_layer_limit M5 -width 6 -area {135.4 135.2 129.4 0} -nets gnd -stacked_via_bottom_layer M1
addStripe -block_ring_top_layer_limit M7 -max_same_layer_jog_length 6 -padcore_ring_bottom_layer_limit M5 -number_of_sets 1 -stacked_via_top_layer AP -padcore_ring_top_layer_limit M7 -spacing 2 -merge_stripes_value 2.5 -layer M6 -block_ring_bottom_layer_limit M5 -width 6 -area {96.6 135.2 90.6 0} -nets vdd -stacked_via_bottom_layer M1
addStripe -block_ring_top_layer_limit M7 -max_same_layer_jog_length 6 -padcore_ring_bottom_layer_limit M5 -number_of_sets 1 -stacked_via_top_layer AP -padcore_ring_top_layer_limit M7 -spacing 2 -merge_stripes_value 2.5 -layer M6 -block_ring_bottom_layer_limit M5 -width 6 -area {53.2 135.2 47.2 0} -nets gnd -stacked_via_bottom_layer M1
addStripe -block_ring_top_layer_limit M7 -max_same_layer_jog_length 6 -padcore_ring_bottom_layer_limit M5 -number_of_sets 1 -stacked_via_top_layer AP -padcore_ring_top_layer_limit M7 -spacing 2 -merge_stripes_value 2.5 -layer M6 -block_ring_bottom_layer_limit M5 -width 6 -area {19.3 135.2 13.3 0} -nets vdd -stacked_via_bottom_layer M1
Hi everyone,
