Problem upgrade Pr*tel DXP to SP2 level
The Puma
Full Member level 2
Full Member level 2
service pack 2dxp
When i tried to upgade DXP to SP2 i get a error
MachInit.exe is not a previous version and could not be upgraded.
Why not ??
Have anybody with success upgraded DXP to sp2
Please send me the original MachInit file please
Please help me
Thx
You probably: installed Protel, cracked it and then install SP or using SP for Trial on Retail version (or SP Retail on Trial version).
Solution for first situation: uninstall, install again, install SP2 (and find the crack).
Solution for second: download proper SP2 file.
Mickey
PS. It is possible that exe is just damaged (by virus, disk failure or something else) then first solution will be useful.
I have a non cracked version. installed with seri@al
i have downloaded the full sp2 package
i will not work
Do you have installed SP1? If yes first uninstall Sp1 and next install Sp2. This worked for me.
Good luck.
mhmhmh,
I have fresh installed dxp
There are two options available for downloading Service Pack 2 for Protel DXP, depending on whether you are using the full licensed version of Protel DXP or the Trial Version. Please make your selection below.
