Problem seeing registers in EFR32FG14 example of GPIO toggling
yefj
Advanced Member level 5
Hello ,I am following the manual.i did put breaking points at the event handler.
I have attached a video where i try to press the step into "9" button and press the PB1 button.
I dont see the logic at what stage should i press PB1 button so i could see my GPIO -> IF register change in value?
What is the proper way to press PB1 button and using F5 step into for debugging IF and IFC registers?
Video of how i tried shown bellow:
https://usaupload.com/6SFG/2023-02-16_15-20-29.mp4
https://docs.silabs.com/simplicity-studio-5-users-guide/latest/ss-5-users-guide-testing-and-debugging/using-the-debugger#:~:text=The classic Simplicity Studio debugger,examine memory, variables and registers.
https://github.com/SiliconLabs/peri...ries1/gpio/switch_led_interrupt/src/main_s1.c
Update:
Hello , PB1 is press button 1 on my board.the GPIO pin which triggers the odd interrupt.
I have some progress andi see my IF register change value when i press the push button and press resume .
But the IFC stays 0 all the time during the debbuging procces .(as shown in the attached video)
Why is that?
Thanks.
https://usaupload.com/6SGZ/2023-02-16_18-41-36.mp4
Have you found the solution?
